CATS shock lower spherical bushing?
Can someone please confirm that the subject bushing is the same for all types of rear shock absorbers (conventional and CATS). The vendor descriptions aren't very precise.
PS I followed Motorman's scissors jack removal technique and it worked great.
Thanks, Bob. I just finished the fronts and used your method to remove the left rear. Also used your part number list for the various "foam" rubber isolator bits. Had my fingers crossed the lower spherical bearings would be OK...no such luck. I ended up buying Lemfoerder replacements from Barratt's (at a big mark up I suspect). I'll know better next time...oh wait, I'll be taking my dirt nap before a next time.
Hope you're well. Happy New year, Eric
motorcarman (12-27-2023)
...for the record, if doing an internet search for a German bushing, the main part number on the factory box for the Lemforder item is 37518 01 ...with a "cross number" C2D4013. SNG has them @ $43...decent price for the Lemforder part. A URO part is in the $25-35 range.
max224
01-12-2022 05:39 PM
