CATS suspension retrofit
Hi,
I’m on the brink of purchasing one of two X308 XJRs. They’re both in genuinely nice condition but neither car was fitted with the CATS suspension.
Does anyone know if it’s possible in theory to retrofit CATS to a 308 XJR? I’m sure it would be expensive and not necessarily worth it but just curious to know if it’s an option.
Is it maybe preferable anyway for whatever reason to not have CATS, perhaps it’s more comfortable without for example?
Hi XJ Ned,
all X308 XJR have CATS. That was not an optional option. It was always included.
As far as I know, that's true for all markets.
Check the shocks on the top if there is a electrical connector. If yes, its adaptive suspension aka CATS. If not, one of the previous owners exchanged the CATS shocks with normal sport ones.
Kind regards,
Alex
Kind regards,
Alex
Ride
Good to know also that it only stiffens up under hard cornering and braking.
I’m not expecting a super soft ride like the old series 3 XJ but I just want it to be as good as it can be for an X308. I might even consider smaller 17” rims if they’d accommodate the XJRs presumably bigger brakes?
Ride / looks
I guess 17s would fit then, I always quite liked the Celtic 17” wheels from the XJ8.
I guess it’s a balance between the good looks of bigger wheels vs the marginally improved ride comfort one might achieve with a slightly smaller rim and slightly thicker tyre side wall. The XJR Asteroid wheels for me look so lovely I’d struggle to part with them.
stefon
11-22-2007 01:52 PM
