CD changer error E-01 SOLVED!!!
I have an '02 XJR, and when I went to play some cd's, my screen showed an error code. E-01. I called a few guys and they were going to charge me over 300 dollars to get it fixed, or have to buy a new one! So I opened up that little sliding door on the cover, took a flat head screw driver, and shoved it in between the case that holds the CD's, and the player. I lifted up the case a bit, and hit the button, and nothing. I messed with it for a few seconds, and all of a sudden, I got it in the right spot with the right force, and it popped out!!!!!!!! Dont waste your money on a new one, or on having someone else do the same thing. This only took a few seconds! Hopefully it will work for you too
The following 2 users liked this post by 2004x-type:
Ian E Huntingdon (04-28-2015),
Ms Peabody (01-17-2013)
I bought my wife a 93 XJ6/XJ40 Sovereign. I then purchased her a cd changer for
this car which was throwing an error code E01. Our manual said dealer....this awesome site explained potential ways to correct this.
Removal and opening the cd changer, manually ejecting the mag ( by rotating the drive gear for the mag eject with your finger-not prying on it), re-connecting the changer with the mag removed allowing the changer to cycle / reset and send the no mag message to radio, and THEN re-installing cd mag and it works like a dream!!!
Cadillac (12-26-2011)
jimforrest (uk)
02-28-2019 06:42 PM
