Center console backlighting Q
@Mark
Yep, everything in the centre console should light up at night. I actually think it's a bit overdone, but anyway.
There are probably at least 5, and maybe up to 10 bulbs that are responsible for the illumination of all the buttons, so it seems kind of strange that ALL of yours aren't working.... it kind of suggests a wiring fault somewhere..... anyway, you'll have to take the ski slope off, etc to get behind to where the bulbs are so you can start testing for voltage, etc to see if its just the bulbs or not
Take care
Take care
I replaced my bulbs when I installed my I-Pod connection. I took a few photos of my install on my xk8 it might help. http://www.gusglikas.com/AutoRepairIpodInstall.htm
Clock --> yes
Drivers side switch pack for windows & mirrors --> yes
Passenger side and rear window switches in the doors --> yes, according to the circuit diagrams.... there was another thread on this. Mine don't but others confirm they should.
3 instruments --> yes (obviously)
front/rear fog switch --> yes
trip computer reset switch --> yes
roof console --> yes
Thanks for the confirmation SARC. I guess I should start poking around the wiring then, because everything but the instruments and the radio/AC screen is out.. I am starting to suspect the dimmer switch because it appears to be inoperative; but I don't understand how it could take out all of the interior lights :s
@Mark
I "think" the instrument pack also works through the dimmer at night, so I'm not sure about the dimmer..... ? If you go to the sticky FAQ thread at the top there is a link to download the electrical diagrams for the car. The interior lighting is shown in detail there..... If you are electrically inclined it may help you isolate where your problem is. It appears from a very quick glance that the instrument pack is supplied via a different wire from the other interior lights, most of which all seem to be powered from one common hub. Let us know how you get on....
I just replaced my Clock Light Bulb yesterday. But due to the $13 pricetag, I opted for LED instead. I used a 6 volt 300mcd Blue LED and added a 270-Ohm 1/2 watt resister to bring the voltage down. It's slightly brighter, and More Blue, but I like it. I think I'll be swapping ALL bulbs to LED shortly. Total price around $3 (RadioShack) and I'll never need to do this again. (Specs were just for future reference).
At any rate, I also checked the function of all lights while I was there, and here's what I have.
Everything lights up! All switches, gauges, clock, etc...
Door Switch Packs (All 4 doors and all switches):
On with Ignition and Headlights
Dimmer Control Works
Clock:
Instruments:
On Dim with Ignition Only
Turn on Headlights to add Dimmer Control and Brighter
Dash Buttons:
AC/Radio:
On with Ignition only
Turn on Lights to add Dimmer Control
Shifter Selector Red Light:
On with Ignition Only
It seems that all the lights you have out need to have Ignition AND Headlights. Maybe your Ignition Switch, Headlight Switch,or your Dimmer Switch like you mentioned. I'm sure someone else will have better input on this.
If you turn your Dimmer Switch all the way forward till it clicks, any change?
Clock:
Instruments:
Dash Buttons:
AC/Radio:
Thanks SuperSport! Your observations and my (limited) understanding of the schematic make me believe that the failure point is either the dimmer switch (which is completely inop) or, more likely, the dimmer control module.
That's the thing with buying a car in daylight - can't see all the little electrical issues... Not that backlighting is a huge issue, more of an annoyance.
D'oh !
Ok, I admit it, I AM AN IDIOT!
It is about 3 am here and I just had my eureka moment. After reading SuperSport's post I realized that I've never actually tried turning the headlights on.. I was so used to my S-type that automatically turned all the backlighting on when the headlights were set to Auto. So, I just ran out, put the key in the ignition, turned the headlights on - and the whole car lit up like a bloody christmas tree... and now I feel very very dumb
I'm sorry for wasting your time gents
Well Done Gus! Once again you've come through for us. I stopped by the dealer today to locate bulbs for the Hazard/ASC/Valet/Door Lock switch on center console, along with a couple others, with no joy. They may find it, but not today. I came home did a search and behold, your link regarding I-Pod install showed bulbs and Packaging. Excellent idea! Thank you.
Any idea on bulbs for the front passenger door window switch, or drivers rear same?
And, one more, the bulb in the back of the round trip computer & fog light switches? These are different from Hazard switch bulbs, I pulled one out.
I'll keep searching.
Call ken at http://www.motorcarsltd.com 1.800.338.5238 He will find the bulbs for you. I think you will find two type of bulbs. The other option is to go to Radio Shack with the bulb you need and match them up. On line Radio Shack is another option but you will need the bulb information. With this option you may need to attach the bulbs to the mount but it should not be a problem and probably cost half the price.
FS[MidAtlantic]: 1997 XJ6 VDP $3,900 - Very RARE Anthracite on Warm Charcoal
42Ajd
09-26-2015 07:04 PM
