central locking issue
Hi can anyone help me with this...I was cleaning my 1998 xj8 a few days ago and accidentally knocked the locking latch in the driver's door, into the closed position, I poked it around a little and it was back in the open position, not too serious .Now when I use key fob it locks/ unlocks but when I get into car and into gear car automatically locks, still ok but when I open drivers door it doesn't unlock all the doors (it used to open all doors) then I have to use the key fob to lock the doors and then again to unlock the remaining doors, is it possible to reset the locking system or what mechanism is inside the door, ..In general now it is not reliably locking I am having to check the driver's door handle and the little silver door lock thingy seen through the window sits a little higher than the others, everything was fine until I knocked it into locked position. I just want it to behave again!!!!!, any advice suggestions appreciated.... Many thanks
Trevor a hard reset is when you put the car back to factory settings in the modules and each door has a module. To carry it out remove the neg- cable from the battery and leave the car go for a coffee. Then connect back up. You'll need your radio code, and seating memory settings re-programming. The drivers door should also come back online, if not it'll be something mechanical in the lock mechanism, like the plastic rod being unclipped.
