Changed coil/plug, still Restricted Performance?
Hello all, newbie here. Maybe someone can point me in the right direction because I'm scratching my head here. I have an 2001 XJR. One day while at the light, the restricted performance code popped up and started running sluggish. Then the check engine light came on. I was in the process of getting the car inspected. I went ahead and let them do the inspection although it didn't pass. They pulled the code and a P0351 code: Ignition Coil A Primary/Secondary Curcuit Malfunction. I had a code reader at home so I plugged it up and got a P0301: #1 cylinder misfire and ignition coil. I replaced the coil as well as the plug, put the electrical grease on the plug, etc. and buttoned everything back up. Cranked the car up and it sound and sound fantastic. Took it for a drive, 30 mile drive. Initially, it ran fantastic. In the 13th mile of the drive, the Restricted Performance Light popped on. It still ran very well and only until you came to a complete stop, could you tell it's not running right. At the end of the 30 mile drive, the check engine light popped back on. Upon returning to the house, I hooked the code reader back to it and the same damn code popped back up! I'm lost. From what I have read, normally it's the coil or the plug if that's the only code that pops up? Am I missing something? Is there an item I'm overlooking? What do I check in regards to that inital code that the guys at the car inspection place brought, the Ignition Coil A Primary/Secondary Curcuit Malfunction. I'm frustrated and any help and or comments would be greatly appreciated. Thanks.
Ok, now I'm confused again. So, let me as this way then. Is Coil on on the side where the brake booster is or is it on the side where the air filter is, both locating themselves at the front of the car. Is there a diagram to show the order of the V8?
Look at testpoint's post here:
https://www.jaguarforums.com/forum/s...linder+numbers
Methinks you changed the wrong one- Don't feel bad, you will note from that thread that I had a brain fart on the correct order too!
Jim
aholbro1
08-05-2021 05:02 AM
Aus V8S
11-13-2015 11:01 AM
