Changed XJR O2 sensors, now no start condition
After living with a check engine light for a year on my 1999 Jaguar XJR due to a bad O2 sensor, I finally broke down and bought 2 new sensors (front, before cats). Drove the car into the shop, put it up on the lift and changed the sensors. Plug and play, right? Not so fast, apparently. The car started one time and then would not start again. The OBD is throwing the following codes:
P0447 - Evap Emission Control System Vent Circuit Open
P0444 - Evap Emission Control System Purge Valve Open
P1224 - Manufacturer Contrl Fuel Air Metering
P1000 - Manf Cntrl Fuel & Air Metering, Auxiliary Emission Controls
I tried clearing the codes, but no luck. The car cranks normally, but does not even try to start. Any ideas or help, please???
Have you knocked any under hood connections or not plugged something back in?
The P1224 is interesting possible causes include
Throttle adaptations not performed after battery disconnect - (try a hard reset but before starting the car pull the plugs and put a drop of engine oil down the bores, it might be a case of bore-wash. If it catches let the car do it's adaptations and idle for 10 minutes).
TPS disconnected (check the connections on the TB)
TPS to ECM open circuit/high resistance. (see above)
Throttle motor power relay failure...(again)
etc etc...
The others are related, if you snag the major issue the others disappear, sometimes
etc etc...
Disconnected the battery and left it off overnight. Reconnected it the next morning, but the car still won't start. The starter spins the engine fine, but it doesn't even begin to try to start.....nothing. Double checked to see if anything was unplugged; everything is OK. OBD still shows the same codes. What am I missing here?
Received 2,193 Likes
mikiep
12-20-2019 07:37 PM
jimforrest (uk)
02-28-2019 06:42 PM
