Changing Alternator
The output is 120 Watts (W) at 12 Volts (V). There is no advantage in using an alternator of different output. Jaguar got it right here.
larney (09-05-2014)
larney (09-05-2014)
Received 9,007 Likes
Just a quick update. Started on the alternator removal today. Took the air cleaner off, then the front pass tire, inner wheel well guard. The bottom bolt was a little tricky. Looking for the socalled sleeve and trying to figure out how slide it back to release the alternator. To make a long story shorter I got it off slide it out the side. Will take it in tomorrow(Monday) get it rebuilt and hopefully install it tomorrow night...
#30
#31
#32
It contains a picture of the "press" used to push the sleeve back into the mounting.
The procedure is described in the JTIS.
#33
not so much a slide as "if you don't get the blasted sleeve to move in a bit you'll be cursing it during reinstall because you can't get the alternator between the two mounting ears on the bracket" ![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
doesn't have to move much, 1/8" will do.
#34
Here is the weblink to DanR photo of the tool he made (post #4):
https://www.jaguarforums.com/forum/x...or-help-59697/
Jim Lombardi
Jim Lombardi
#35
RESOLVED!!! Just finished the install on the rebuilt alternator. Started it up. No problem. Turned all the accessories AC, Radio and lights... In drive w/brakes on read 13.3 volts at the battery. With everything off and idling 13.7. No warning lights on the dash. I drove around for about 20 minutes and no issues. Before it would take about 5 minutes or until you turned stuff on. I would recommend anyone doing this on a 2000 XJ8 for sure to use these directions...
xjravon xjravon is offline
Garage is empty, add now
Default Very easy to remove do it in 20 mins or less
I have a 2001 xj8 the easy way to do it with out removing all that stuff is to
1 disconnect the battery
2 disconnect the air filter cabin not completely but just enough to get it to set to the the driver side of the engine
3 loosen your tires on the front passenger side and jack up your car remove that tire take off or loosen the splash guard in that wheel well i just loosened it
4 Go to the top under the hood loosen the tension-er so you can get the belt off of your alternator off to do this when you loosen the bold hold it with a pry bar when it loose take the belt off and release the tension-er slowly
there are two screws that hold the alternator on the bracket take those out from the top under the hood one is below on the bottom of the alternator which you will have to get under the car and the other is on top on the side where you had removed your air filter cabin there is a NUT IN THE BACK WHICH YOU HAVE TO HOLD ON THE SCREW ON THE TOP WHICH IN BACK OF THE ALTERNATOR
5 some people may have a splash guard in the undercarriage remove that
6 wiggle your alternator and it shall come some what free
7 go back to under the hood and reposition your alternator and take the positive boot off the harness and remove the nut and remove the wire from the alternator
6 from under the hood of the car again take the clip that was next to the nut you just removed off the alternator with a pair of pliers be sure not to squeeze to hard you may break the clip this will take off the second harness
7 take the altoneater though the body of f the car and slide it though the lining of the wheel well
Repeat backwards to reinstall
WARNING DON'T KNOCK YOUR SELF OUT TRYING TO REMOVE THE AIR FILTER CABIN IT WILL SPLIT YOUR WIG IF YOU TUG ON IT IT A RUBBER BOOT CUZ I SURE DID LOL GOOD LUCK!
These were spot on...
Thanks for ALL the input and advice. Sure makes the job easier...
#36
aholbro1
08-05-2021 05:02 AM
Gerard Radimaker
09-13-2015 10:33 AM
