Changing brake fluid - how much needed?
Vector....2 litres should do it for a full flush.
Taking into acount that if you have Brembo calipers, they will have two bleed nipples each at front.
Bleed sequence is:
LHF - RHF LHR - RHR
If you use the conventional method via pedal use full long strokes gently....don't go pumping away madly.
A pressure bleeder (easily available via Amazon) is definately a better way to go for a complete flush and doesn't run the risk of damage to the master cyclinder bore/seals by constant pedalling.
Bleed sequence is:
LHF - RHF LHR - RHR
BrentGardner
28
04-26-2024 03:08 AM
FS[SouthEast]: 2005 Jaguar XKR Convertible Supercharged
divingmom
08-25-2015 07:54 PM
