Changing the drive shaft rubber (Jurid) couplings
After taking advice from my local mechanic, I've ordered replacement rubber (Jurid) couplings for either end of the drive shaft. Then, today I looked at the service manual where I found the following quote " Under no circumstances may the flexible (Jurid) coupling be removed from the driveshaft (or it's fixings loosened)."
Is this Jaguar covering themselves in case of resultant balancing issues, or can I reasonably ignore the warning? The cost of a whole new driveshaft is very different to the cost of the rubber mounts..., but a broken driveshaft could very well cost more again to repair...
Has anybody done this repair or have advice on how to proceed?
Received 10,898 Likes
My X300 manual says the same.
Everyone and his brother ignores the warning and replaces 'em. And, shoot, Jaguar itself sells the couplings.
Pay attention to the orientation. There are arrows on the coupling showing which way the bolts pass thru. If you *remove* the driveshaft make sure to mark the exact position of the center bearing mounting brackets
RichardPhuket (11-07-2014)
Drive Shaft Bearing change, 2001 XJ8
The rubber 'Jurid" couplings finally arrived from the UK, and when the mechanic came to fit them, he found that the bearing in the middle / rear part of the drive shaft also needs changing.
I've looked at some threads on this and am not sure whether it is possible to change just this bearing or whether I will need to buy an entire new drive shaft!
Can anyone advise me about this please?
RichardPhuket (11-25-2014)
BrentGardner
28
04-26-2024 03:08 AM
Fraser Mitchell
10-01-2015 04:06 AM
