Changing rod bearings
I replaced a bad motor with a broken timing chain cylinder head was broken same with the piston it could’ve been fixed and it was a shame because it only had 60,000 miles on it. But when i swapped it with a different motor my life so much easier it was a big job just to do that I could always see the end of the road with the project. I put an xj8 in a xk8... And it worked out good after a month I have a leak in the front of the motor probably a water pump etc. but to do a rod bearing I could only imagine
djr48312 (07-09-2021)
I actually took a 4.0 AJ27 NIKASIL block and had steel liners installed at a machine shop.($60 per hole) I measured (plastigage) and reused the main and rod bearings. (they were within tolerance)
I worked at the dealer so I had a few old/failed NIKASIL engines that were to be scrapped so I thought WHY NOT?
The cylinder heads were good so I bought new rings for the pistons in the new liners.
Time consuming but not difficult. I already did the Engine Course 180 (later is the 168) so I had the experience and manual.
I used the same crank that came in the block so no bearing difference and I used the same connecting rods in the same journals so no change there either.
If I ever had to replace a crank, I would just replace the engine block/crank as a unit with good-used to keep the bearing selection out of the mix.
There is a matrix to determine the bearings but I just let the guy at the engine factory do his job and build the engine the was it was 'back-in-the-day'.
I know how to do it, I just don't want to.
djr48312 (07-08-2021)
The 4.0 blocks/cranks are ALL THE SAME.
I needed an engine for a 2000 XJ8L (AJ27) and I had a good 4.0 AJ28 from a 2002 S-Type with a bad head.
I stripped the AJ28 heads and upper oil sump from the block/bedplate and installed the AJ27 upper sump and heads.
I now have a perfectly suitable AJ27 engine in my 2000MY X308. (with a 4.0 S-Type block)
Just use what ya got.
Yes you can change the rod bearings by dropping the pan on the XK8 . Engine cradle is
Has anyone ever tried changing the rod bearings while the engine is still in the car or is this completely impossible? The way I see it, the crankshaft is above the oil pan, so I would simply need to remove the oil pan to get to the crankshaft. From there you basically unscrew the rod and replace the bearing.
Am I being realistic?
Yes you can , but you have to drop the cradle.
There are no 'main bearing caps'. The crankshaft 'bearing' caps are actually a 'structure' so access is limited to the connecting rods.
The subframe is another limiting factor.
Please read and comprehend the Jaguar Engine Course 168 I had converted to .pdf from a paper 3 ring binder issued from Jaguar training class.
The bearing selection matrix is complicated and might change your mind about things?
#30
motorcarman (01-24-2023)
aholbro1
08-05-2021 06:02 AM
aktell
09-10-2015 03:55 PM
