Changing transmission Valve Body
My 98 XJ has abrupt shifts between first and second.
After not having any luck with fitting a new Transgo valve, I'm thinking about swapping out the valve body with a used one. It seems pretty straight forward unless I mistakenly open the valve body up. Does anyone have any words of wisdom / advise on the subject?
I would agree switching the valve body is the best and fastest option. I installed a Transgo valve kit also and was stumped that it was having the same slipping problem on my Mercedes. I got a junkyard valve body for cheap, installed it and the same problem occurred. Now I know I have a slipping clutch pack!
Slipping clutch pack situation - assuming correct fluid, level and proper valve operation, then it is either worn clutch friction material or clutch piston leakage.
CleanJag
01-22-2016 08:17 PM
