Charging System 2002 VDP
The car suddenly started staling and the ABS warning light came on. The car finally stopped with a dead battery. I got a hot shot and things were fine unless I slowed down or stopped. I replaced the battery but now I have the engine light on. Is it the battery or the alternator.? Note, While I got a hot shot I read the voltage at 10.5 Volts at idle, but the battery was dead, so I think maybe it was a useless reading. Does the Jag have an idiot light if the alternator or/and regulator is not functioning?
RE: Charging System 2002 VDP
words that are true.. lol
also check the power studs.. to the left of the battery.. the power nuts come loose and then melt.. causing intermittent voltage drope.. and also under the hood right side power post.. cable running from engine to under right side engine bay cover.. they melt and come loose..
Ok! I had it checked and one fellow said the charging system was good, and one said it was bad. So, to make things simple I determined it being bad because I hear a whining from the engine department. My guess is I lost a diode or and a regulator. Any comments?
I must have missed the part there about the whining.
Remove the drive belt and see if noise goes away. If so, turn alternator pulley by hand. You can normally feel it clicking or binding up. If so, replace the alternator.
If the noise is still there with belt removed and engine running.....you have bigger things to worry about than the alternator.
Queston to FactoryJaguarTech
1993 XJS 6Cyl
Alternator smoked dash voltage drop to 9vts Replaced alternator dash voltage 13-14 vts. No charge on battery. Red battery light on dash. Suspect burnt brown wire between starter and battery....Am I on the right track?
1993 XJS 6Cyl
