check gas cap
Well, my almost new 2001 VDP has a check engine light and a check gas cap message. I have cleared the error code and installed a new gas cap, though I suspected that was not the problem. Sure enough, after about 50 miles, the check gas cap light came back on. I am guessing this is a problem some of you have had, so any words of wisdom are welcome.
P0455 can be caused by a failure of the purge valve canister valve or a bad hose. It really means gross leak detected. Use the search function P0455 and you will find lots of suggestions.
P1000 means the ECU has not completed emission tests. It will be replaced by P 1111 when everything checks out.
