"Check Gas Cap" Indicator Light came on.....
Guest
Posts: n/a
![Exclamation](https://www.jaguarforums.com/forum/images/icons/icon4.gif)
Hey guys! Ive ran into a small problem. I was driving this morning, (2001 XJR), and out of nowhere the "check gas cap" indicator light came on. Ive never ran into any problems with this vehicle before so it puzzled me. I had about 1/4 tank of fuel so I decided to pull into the Gas Station. I put the nozzle into the tank and start pumping and it stops at 95 Cents. Ok, I try to start the pump again and it keeps stopping, it won't let me put in ANY more fuel at all. I thought it must be the pump, so I switched to another one. Still, it wouldn't pump more than 10 cents. The fuel would try to run out of the fillup like I had pumped too much fuel into it, very strange.
My question is, has anyone ever ran into this problem and what would be a good thing to check first? Would it be the Purge Valve?, Cannister Valve?, or maybe something on the Evac. System? Any help would be much appreciated!
BTW, My car is A 2001 XJR. Thanks!
Guest
Posts: n/a
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
KarimPA
09-03-2015 07:32 PM
rachelstr
09-03-2015 12:59 PM
