Check Rear Lights
Check Rear Lights
I keep getting the check rear lights code on dash. but i have checked bulbs and wires and all is working. I also had a friend stand behind the car with the check rear lights was on and every light works my blinker my rear fog or whatever it's called and both left and right brake light and regular back lights work as well. and my reverse light works and the third brake light works as well i am stumped and have no clue. does anyone have any suggestions or have the same problem?
The following 2 users liked this post by sparkenzap:
ChrisArlint (06-27-2014),
Rlover (06-13-2014)
When I bought my car, it had the exact same problems.
Take the plastic boards out (turn the clip 90 degrees, and unlock the connector).
Take all bulbs out, and bend the steel brackets for each bulb slightly, in such way that the bulb is held tighter when you insert them.
If the bulbs are tight on the + and -, the warning will not occur any more.
The problem is caused by a very slight loss of contact.
