"CHECK REAR LIGHTS" everytime I step on the brake
Anyone have any idea why this would happen? I have changed the brake switch, checked the tail lights (all of them). They are working fine. A friend has a 2000 XJ8 and his lights work just the same but no "CHECK REAR LIGHTS" when he steps on the brake. Any ideas?
X350's have LED rear lights, so yes quite likely nobody reading the X350 forum had that problem...
As our friends at Coventry Foundation suggest, you should exchange your brake light bulbs for some quality brand-name ones, or maybe even genuine Jaguar ones.
Good luck.
chris-jag (07-14-2019)
(I hate mystery cars)
Before you whine about how nobody will give info about your car........... How about telling us what car you have????
I'm out!!
bob
The following 3 users liked this post by motorcarman:
Z07Brandon (07-06-2019)
On this forum, there are many threads on what your problem could be. Please review them. With the information you have provided, it sounds like you have a bad SLCM. Need to go under your boot carpet, on the left side, and you will see a listing of key modules. You need to buy one that matches: the frequency is important.
I had the same problem, only not every time I put the brakes on, but often. I took out each bulb and cleaned them and the socket, whether it looked like it needed or not. that seemed to cure the problem for me. Oh, and when I put the bulbs back in the socket, I put a bit of bulb grease on to help deter further corrosion
princemarko
06-07-2022 11:23 AM
Reid William Kaufman Worthen
01-01-2019 08:49 AM
Julian Cedrone
03-10-2011 12:52 PM
