Check rear lights message
The lamp current detect is a hardware circuit in the various modules that light lamps, and AFAIK, you could only deactivate it by cutting the leads on the boards. The better method is to install load resistors in parallel with the bulbs so that the correct current is still being drawn. If you can't find properly sized load resisitors from the LED lamp guys, then you need to find the current draw of the original bulbs and use Ohm's law to calculate the required resistor for each circuit.
remccallum (09-17-2015)
BrentGardner
28
04-26-2024 03:08 AM
philwarner
12-06-2021 07:13 AM
Isoruku
06-19-2020 12:54 PM
