check strap / door panel removal
Old 05-21-2013, 11:46 AM
kyle04's Avatar
Default check strap / door panel removal
I will have to remove the (drivers side front) door panel to replace my annoying check strap (that dosn't check).
On my X300 the wood trim panel had to be removed due to a retaining screw underneath. I know I will have to remove the door handle escutcheon screw and the door armrest screw. Does the door panel just unclip around the edges after this, or will I have to remove the wood trim as well.
On inspection and looking at the JDHT schematic it appears that the panel is one piece, rather than two separate pieces as in the X300.
Any tips welcome, including how not to mash the plastic strap covers when removing to get to the screws.
Many Thanks
AndyP
Old 05-21-2013, 01:58 PM
MoscowLeaper's Avatar
You'll need to remove a wood trim.
Gently pull the rear end of the wooden trim to let it come out of the clips and slide the trim backwards.
The panel is one piece.
Don't forget to remove the screw from the door handle.
kyle04 (05-22-2013)
Old 05-21-2013, 05:04 PM
jimlombardi's Avatar
Received 1,622 Likes on 874 Posts
Here are directions/illustrations on removing the driver side front door panel:
https://www.jaguarforums.com/forum/a...l-76-34-01-pdf
https://www.jaguarforums.com/forum/a...t-76-34-22-pdf
https://www.jaguarforums.com/forum/a...l-76-47-11-pdf
Here is a weblink to forum thread on replacing the door checkarm - look at post# 6:
https://www.jaguarforums.com/forum/x...w-36075/page2/
Jim Lombardi
The following 2 users liked this post by jimlombardi:
kyle04 (05-22-2013), WaterDragon (08-11-2013)
Old 05-22-2013, 11:06 AM
kyle04's Avatar
Amazing, thanks guys.
AndyP
D.K
12-10-2023 02:05 AM
XJsc-guy
11-23-2015 01:56 PM
bdboyle
09-04-2015 06:16 AM
obwoodie
09-03-2015 07:45 PM
davidladewig
09-03-2015 06:32 PM
Quick Reply: check strap / door panel removal
