checking trans fluid
smith356 (02-28-2015)
Received 13,090 Likes
I would add a few additional thoughts: In my experience COLD readings are less reliable than HOT readings, so it's a good idea to take the car for a good 20 minute drive before you park it on a level surface, hold your foot on the brake and move the gear shift lever through each gear and leave it long enough for the gear to fully engage, then return the lever to Park and check the fluid level on the dip stick. Being overfull can be as bad as being low, so you want the fluid level exactly on the HOT line. If you accidentally overfill it, you can use an inexpensive fluid transfer pump to remove the extra via the dipstick tube.
Cheers,
Don
smith356 (03-04-2015)
aholbro1
08-05-2021 05:02 AM
Wes Steenrod
09-06-2015 06:52 PM
