Chunk/Thunk Sound in Rear Pass Side
Every time I go over a bump, seam, small wrinkle in the road I am hearing a new thunk-chunk sound in the rear. Put it on a lift, pulled all wheels and there are no mechanical or structural issues -- no wear or malfunction in brakes, pads, rotors, springs or shocks. Trunk/Boot clear. Battery secure.
Ideas?
Thanks.
Ideas?
Thanks.
Hi I have a 07 jag xtype diesel 2.0
I have the same problem near side rear bump thump exactly as you describe had it up on lift mechanic went round all joints with jemmy bar all joints bushings exhaust everything we could prise or stress still nothing we are going to try some the underseal pls any help would be appreciated as I have a 300 mile journey in a few weeks
willybilly
willybilly
Ideas?
Thanks.
Ideas?
Thanks.
Thanks, Motorcarman! I have followed your advice for years especially because you are not far from my wife's home town, Wichita Falls.
Are there parts to replace the foam rear damper bushings? Is there a better substitute than foam? I dont yet know if that is the problem, but it would a good place to start and I'd like to know what the part choices are.
Thanks!
Thanks!
Is the rear subframe similar to the previous car ? It was a regular job with these to replace the "A-frame" subframe bushes.
https://www.jaguarforums.com/forum/x...shings-132485/
Everyone, We found the culprits causing the thunk/chunk sound in the rear. Motorcarman was correct! Congratulations. It was the big donut foam bushings as he described, and the worn insulators and bushings at the rear shocks. The only way to replace the shock insulators and bushings was to replace the main shock set up, which we did. They were 10 years and 50,000 miles old. But the big donuts bushings were probably the main cause of the noise.
Thank you all for your help.
The following 3 users liked this post by Len Apcar:
Mistahchin
08-07-2010 09:49 PM
