cigarette lighter on a single fuse?
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
i have two 2000 xj8(s)....one is a long......i do not use the cig lighter outlet....but recently tried to charge my smart phone....using the outlet.....i noticed the red light on the charger.....would not light up and the phone would not go into charging mode.....so i tried the cig lighter /mobile phone charger on the other jag.....it worked fine....
in the long where the charger does not work.....in the cig lighter.....i can not see any loss of function in any other electrical out put.....dash lights are fine interior lights fine, horn, heater, ac all working fine.....leading me to ask...
is the cigarette lighter on a single fuse?.....of course the other possibility is that the insert/socket of the lighter is bad or needs to be replaced... and juice is not getting to the charger.....but i think not, the inside looks brand new and secured.....and probably never used....so what is going on?.....i am checking my user manual right now...to locate where this fuse is.....
![Smile](https://www.jaguarforums.com/forum/images/icons/icon7.gif)
thanks old mike.....checked fuse location on both my jags as booth 2000....fuse for both located in the trunk......yes its location is number 5.....there is a blank/fuse missing in #4......tested the old which was ng......but a 30 amp.....same for my other but was a 25 in it.......probably blown before and previous owner uped it to 30......in any event working fine and now charging my mobil/cell.....thanks to all
