climate control only hot air
so another problem appeared with my x308 jaguar, climate control blowing only cold or max hot air, if i set to low it blows cold air, then if i set to 17C it blowing very hot air, same as max.
where to look? maybe interior temperature sensor? maybe need to replace all climate control module??
sorry for my bad English
First there should be a button on the climate control for outside temperature. Press it and see if the outside temp is fairly close to the actual temperature. The ambient air temp sensor can play havoc with the controls if it has gone bad. Mine would give heat except on HIGH. The ambient was reading 137 degrees F when it was 32 degrees outside.
There is also a sensor that can get plugged up it is the cabin temp sensor. To the left side of the steering wheel you will see on the dash a perforated area. That is the cabin sensor and aspirator fan inlet. Try a vacuum cleaner hose over it to remove dust and lint.
There is a self test that will give you a code if it is electrical and not if it's dirty .
http://www.jagrepair.com/images/Trai...des/703_SG.pdf
Page 45 for X308 and page 110 for self test , codes somewhere else
Codes pdf in post # 8
https://www.jaguarforums.com/forum/x...nfo-faq-66454/
keithbush
11-13-2014 02:32 AM
jag_guy_2020
08-16-2014 06:17 AM
richard300
04-12-2014 01:09 AM
sandrewfla
42
06-23-2010 04:10 PM
