Good question . . . can you not pop the clock+vent wood veneer panel off and measure it? It comes off quite easily. The only precaution is to work it off equally in all 4 corners without twisting.
Best wishes,
Ken
The less I handle that brittle dash the better lol. I'd like to open it once to refit clock, then be done with it.
The dial/face has a diameter of 38mm, maybe a hair less (37.5mm should do).
In the original design (generation I), the face is recessed in a plastic housing.
I don't want to destroy mine, but I think you probably can remove the original face to prevent a too thick of stacking.
The center hole in the face is ~2mm.
That's near perfect for what I have in mind ! I'm going to buy one off E-Bay to experiment w/ first.
So apparently my "esteemed master watch smith" vendor did not measure it accurately, it is several mm's smaller than described & will just look tacky/out of place if used. On the plus side I found a local guy who is buying the dial for almost double what I paid, all's well that ends well lol.
