clock light bulb for 1998 XJR
You'll need a OEM bulb, as this special bulb is of a blueish/greenish color.
To exchange the bulb you have to remove the center vent.
- Pull off the center veneer
- Pull off the veneer cover of the instrumant cluster
- Pull off the veneer covering the passenger airbag
- remove a few philips head screws and pull off the center vent
- Now you have access to the clock
(Part # of the bulb is imprinted on the back of the clock)
HTH
David
HTH
David
HARV (01-01-2011)
99xk8guy
06-05-2023 06:28 AM
Rlover
03-30-2016 10:04 PM
