Clock stopped working
X350 run a completely different harness and clock.
You need an X308 clock, plenty of which are on a particular auction site, pretty simple to change, by pulling the trim panels off, removing 4 pozi vent screws and unclipping the clock. I would suggest fitting a new bulb to whichever clock you decide on, there are a couple of different styles depending on model year.
Early clock on the left. Later clock on the right. I know the 98’s had the early clock. I’m not sure when the later clocks were installed. My wife’s 00’ XJ8 has the later clock. So either the later clocks were in the 99’ MY or 00’ was the first year.
This is the early clock part number. 4 pins.
Later clock with 6 pins.
I have an early clock in my 03’ SV8 so don’t worry about number of pins. I was just pointing it out. I didn’t realize there was a part number for the bulb on the sticker.
My 01 obviously has the later model.. Very functional, but I think it doesn't look right...its kind og cheap looking to me compared to the rest of the interior.
Apparently the dash clock out of an Aston martin vanquish will fit directly. I kind of like this look, goes with my oatmeal seats and is still quite legible.
Interesting idea.
https://www.jaguarforums.com/forum/x...anquish-87213/
Interesting idea.
I like the look too, the cream color would work well with my oatmeal interior I think. Trick is to 1) find one and 2) have it not be $200 because its an Aston Martin clock. If I found one for $40 or so I'd be on board.
Send me your payapl...or venmo or whateverthehellyouuse.com
Thats a specatular car with a LOT of Jag (and I'm sure other FoMoCo subsidiary) bits in it...the whole center stack, its slightly rearranged, but wow! True unattainable dream car, especially with a stickshift.
