Code P0128 A Sensor?
Received 2,193 Likes
just put an ew 1 in and clear, Im assuming you have the new multi piece t stat cause the old ones never kicked that code. They just overheated the engine sticking closed. Youll find when you pull it out that the rubber seal around the edge of the thermostat itself has a small tear or piece missing letting coolant bypass causing the threashold to not be met, Ide rather have a t stat stick open over closed any day
Guy-Pierre Boucher
09-16-2015 05:55 PM
joesoap
09-10-2015 01:09 AM
