Code P0300 Random/multiple cylinder misfire detected..and others
Helpful to know the kilometres/miles on the vehicle.
What is the battery voltage across the terminals with the ignition in the OFF position when measured with a voltmeter?
What is the fuel pressure?
Are the cam cover seals leaking?
Have the spark plugs been replaced?
75k miles on car
spark plugs and coils replaced about 20k miles ago
cam cover seals not leaking
Remove the spark plugs from the cylinders indicating misfires and inspect for oil in the spark plug wells. Oil fouling is a major cause of ignition coil failures.
Don B (03-19-2023)
Voltage needs to be checked with ignition OFF using a voltmeter. Minimum available voltage for all modules to correctly function is 12.6 volts across the terminals.
will check for oil.
odd when running and skipping and restricted performance and check engine light showing... When I clear the codes it runs perfect for about 4 seconds .
The following 3 users liked this post by David N. Warner:
Willyb
12-17-2013 03:51 PM
