Codes found!
2000 XJR 65K miles
Checked as a result of check engine light and performance restricted message.
here are the codes that showed up
P0171
P0174
P1111
I cleared them all,
then under acceleration the P0171 came back. The scanner shows it as bank 1 lean.
I do feel under mild acceleration, it slightly stumbling a tiny bit........
Ideas?
Thank you all for your help.
P0171
P0174
P1111
I cleared them all,
Ideas?
JG I just checked the air intake from MAS to throttle body, smoke and noise indicate no
obvious leakes. But I did notice a bit of oil in the air intake tube, no doubt from the PCV fitting......is the oil in the air intake normal?
Also the air intake tube does not seem to be real tight where it goes on top of the throttle body....is there supposed to be a clamp on it there?
Could that be the culpret?
Fuel trims while running are all in the +0 to +25 Unless I am off the throttle completely when coasting up to a light.
Then SOMETIMES they drop to as much as -30 but very rarly......what is the correct procedure for checking the Fuel Trim on the scanner?
MAF also seems good on the scanner. It goes way up and down directly realted to the engine speed.
Whats the next step? Throttle body clean or change out completely?
I really want to get this car running puuuuurfectly.
joesoap
09-10-2015 01:09 AM
OkieTim
09-08-2015 04:48 PM
