Coil Cover Bolts
Its nice to meet another Jag owner from Omaha.
I removed one of mine and measured it. It is 4.87mm diameter X 12mm length.
I believe they would call that an M5 x 12. if not an M4 x 12 if you are not going to buy them at Jag for about $5.00 each I would recommend adding a flat washer since the OEM is a flange/shoulder type bolt.
Send me a PM and I will introduce you to a few of the other Jag owners in Omaha.
soprecious (01-04-2016)
I posted it on here a while ago... I can dig up the thread about it..
I bought all my bolts from Fastenal (88 bolts in total) for about $22.00.
They can match the bolts used on the coil cover exactly. They have a few different options, I opted for the oiled flange bolts, I would also suggest class 10.9 (american grade 8). I will find it and post it for you.
__________________________________________________ __________________________________________________ ___
EDIT:
https://www.fastenal.com/products/details/11127077
those are the correct bolts. They are also the same for the coil packs as well as the covers.
The only difference is instead of being a 7mm head like the factory ones, these are a slightly more common 8mm head.
EDIT:
EDIT:
EDIT:
tiger351w (09-07-2023)
nebelfuerst
01-03-2016 11:42 AM
