Compression Gauge recommendation?
I am having problems finding a compression gauge to use that has an extended pressure tube to reach down into the spark plug opening. Can anyone suggest what they use? The ones I have seen have a short adapter and then a flexible hose, which I didn't believe could be used.
Any thoughts?
Thnak you very much!
<<<Mathew>>>
Any thoughts?
<<<Mathew>>>
X308XJR
05-20-2019 06:50 PM
