Computer Code 1797
I have no direct information on this but this might help! http://www.gusglikas.com/images/Auto...tem%201999.pdf
The ECM and TCM (and ABS) communicate through a CAN buss (controller area network) that is a high speed network. The fault code means that there was a missing communication between the the 2 modules. It could be a harness or connector fault. (less likely a module fault) It will be easier to find if it is a permanent fault. It is harder to find an intermittant fault because you have to guess or catch it when it happens.
bob gauff
The ABS module is mounted on the inter fender panel at the left front of the engine. It's that thingy with 6 rigid brake lines coming out the top. There are two connectors. Remove, clean, dielectric grease, connect. The ABS module has a history of breaking the connector contact on the circuit board and causing come-and-go codes. It can be disassembled, soldered and reassembled. Try the connectors first.
philwarner
25
06-26-2021 05:43 AM
