considering buying '00 xj8 with trans problem
Guest
Posts: n/a
Hi, im mostly new to jaguars and Ive been looking at a few xj8s. I have a question on one, its a 2000 with about 100k. Apparently the trans will not go into reverse when cold, after a couple minutes it will and no other obvious trans problems. Does anybody know of any possible simple fixes for this, or is it more than likely the start of a fatal transmission issue?
Also, if it is a slipping trans, how bad of a trans it is to rebuild? Im a GM tech and have experience in most of our 5 and 6 speed autos, but am completely unfamiliar with the jag unit.
thanks!
thanks!
Received 2,190 Likes
