Converting An Automatic Transmission To A Standard Shift
Was doing some research on transmission conversions on 90's vehicles. Wondering if anyone has any recommendations on brands for a new transmission and parts. Since I would have to take the exhaust off to fit the new tranny I could use some recommendations for aftermarket exhausts for a 98' XJ8.
it's a bit specialist - I've not seen a forum member carry out a conversion on these cars, and considering the transmission issues with the ZF fitted, that can only mean it's very difficult.
Reason - the car's electrical system, it has something like 13 modules linked, take one away the car is a brick.
There are black boxes out there that can trick the system, but these are costly and I know next to nothing about them.
Manual transmissions, the Getrag fitted to some M cars, and a pedal box assembly from a manual X300 or XJS might aid the mechanics - but an adaptor plate will need to be made.
There is a manual + LS converted car on youtube that mentions the hardware in some detail, I suggest you watch that, and digest the sums mentioned on the conversion.
Good luck and let us know how you get on.
Hi I used 5 speed gearbox from BMW E46 Mtf lt1 and clutch from e36 with solid flywheel. After I made fixing plate I realise I could put 6 speed gearbox. All conversion kit I did my self and cost me in total about 450£ Ecu thinking gearbox is on Neutral gear, I had to left solenoids and gear selector sensor with the car so he don't show error message.
Also this Franken-Jag
iculyn
04-01-2013 09:21 PM
Staatsof
27
08-23-2010 12:47 PM
