Coolant Crossover disintergrated
OK, beat me now. I should have done this 2 months ago when I was doing the full timing chain swap, but both the crossover and thermostat housing, appeared solid. I'm wondering if allowing them to sit dry for any period causes a breakdown in the plastic, but that's another thread. Today the wife informed me the car was smoking. A quick inspection pointed to the top radiator hose connection to the crossover. I grabbed a new clamp and quicly realized the nipple was mush, I'm assuming this is the same failure experienced with the thermostat housing so I'm getting ready to order both. I had no problem finding an assortment of all metal upgrades for the thermostat housing but all I'm seeing for the crossover appear to be the same OEM plastic components. Anybody know if there's a metal crossover option,and who has it?
I searched for a metal distribution pipe to no avail. My pipe was also pretty brittle and weak when I replaced it. But the new plastic pipe was a big improvement and came with a fresh temp sensor.
I'll keep watch for a metal alternative and plan to replace again in a couple of years regardless.
X308XJR
05-20-2019 06:50 PM
