Coolant full but light is on
Guest
Posts: n/a
RE: Coolant full but light is on
Coolant level sensor is bad. Have also seen the light come on because of the expansion tank being bad. I would start with sensor, if light stays on take it back and exchange for tank. Level sensor is on bottom of tank and new tank will come with sensor in it.
Guest
Posts: n/a
I have a 2003 S-Type and my low coolant light is onbut the reservoir is full. I took it in to a local garage to renew my state inspection and they saw a leak but do not know the source of the leak without an more extensive check over. He thinks it could be a serious problem if the coolant is not getting to the engine. Do you agree? I may be trading my S-type in for a newer model in a few months. Should I be concerned about this "leak" or have it looked at?
KarimPA
09-12-2015 08:15 AM
OkieTim
09-08-2015 04:48 PM
KarimPA
09-03-2015 07:32 PM
