Coolant hose 'connector' question
Greetings,
I think I just about replaced all 'coolant' related on my XJ8, but a plastic 'T' recently broke on the coolant hose matrix which forces me to replace the whole thing (I had replaced a valve in it before though). So how do I disconnect / re-connect what appears to be a 'clip in' connector system? See picture. Something tells me might need a dedicated tool... hopefully not. Access seems miserable. Thanks a million!
Many thanks Vern. I was able to remove old hose/connector (scary as the black ring kind of moved easily though... probably an imminent problem anyway). I reconnected the new hose without the 'green plastic ring' and leaked. I figured that green plastic thing must have been there for a reason... so will try again with that.
OK.... so I FINALLY got this NORMA connector to fit and locked in. Drum roll..... it leaks! #%$ A small drop every second or so, seems like coming from the little visible 'hole' in the core of the connector. I searched on the forum here and I seem to not be the only one with encountering a similar problem. I have read about a potential manufacturing defect and need to return the part... really? so many defective parts been produced? Just want to hear some thoughts before I go bonkers....
car5car
08-12-2019 06:33 PM
jagdohrman
07-01-2017 11:36 AM
mzs_biteme
03-06-2013 01:38 PM
Michael Star
01-30-2013 09:31 PM
