Coolant hose under supercharger
As per HH a search will reveal info on this, I think this is one may be one of the most informative.....................
https://www.jaguarforums.com/forum/x...harger-152089/
I’ve basically decided since it’s a 2-3 hour job pulling the s/c I’m doing everything that can be done. Valve cover gaskets, knock sensors, new pulley, rebuild the snout, have the s/c checked for clearances and rebuilt if needed, all hoses, and since I already removed the throttle body I’m gonna strip it down and thoroughly clean it too.
Not sure what your plan is for the supercharger, but I would at least change the oil, and coupler (use a new OEM coupler).
Replace the part load breather tube while you’re under the SC. It will be extremely brittle and will probably crumble when you touch it, but it is plumbed to the intake elbow under the throttle body, and you will have a massive vacuum leak if you don’t replace it, even if it looks ok. It happened to me. In my case, I was able to replace it later because the line does not HAVE to run under the SC, but life would have been simpler had I just replaced it while I had the SC out. Also clean out the port where the part load breather tube goes into the engine in front, using a small drill bit, held in your hand. Do not drop the drill bit in the engine! I clipped a small vice grip on the drill bit to be safe.
Might as well change the SC oil while you have it out.
kert1224
12-21-2015 12:31 PM
gkt33
12-06-2014 02:26 PM
justwant2drive
35
08-23-2013 12:47 PM
josh_77073
11-22-2012 04:28 AM
