Coolant leak help..(video attached)
![Exclamation](https://www.jaguarforums.com/forum/images/icons/icon4.gif)
Hi,
I have an issue with a coolant leak on my car. It's a bit odd if I'm honest.
The leak only occurs from the left side not far from the tank, after I drive the car for a while or when I drive erratically.
Once the leak stops, I'll immediately refill the tank with water and the leak stops...
The video attached may not show much so I do apologise. (for some reason I can't add a second video but that was showing the leak from underneath.)
Any help would be seriously appreciated, thanks.
Received 1,794 Likes
Unfortunately, if its a seam, it would mean removal of the radiator. But, it could be a minimal cost repair for a radiator shop and all they have to do is solder it, pressure test it, and your good to go.
If the radiator would have to come out, a detailed inspection of your hosing and replacement of weak hoses, would be highly recommended. This should be done in any case.
mikchek
08-17-2018 06:06 PM
Sonspit
02-19-2015 10:26 AM
