Coolant leak - Outlet cross over pipe
Having successfully battled to replace the thermostat housing which was a bit of a challenge I've put everything back together and there and am now getting coolant being pushed out at the joint where the outlet cross over pipe is attached. There didn't seem to be any O rings on the outlet join hopefully that's all I need.
dumbest post ever possibly. O ring found beneath the car.
Edit: even as I was removing the bolts I distinctly remember wondering why on earth they would need 6,000 bolts to hold the water pump on. Haha
jessquirl (02-04-2023)
