Coolant Leak with Picture
Old 02-25-2008 | 01:30 PM
CarBizIndio's Avatar
Default Coolant Leak with Picture
http://i69.photobucket.com/albums/i7...o/DSC01327.jpg
http://i69.photobucket.com/albums/i7...o/DSC01326.jpg
Looks like its at the top of the thermostat housing. Is there an O ring or some kind of gasket that can be replaced under that cap?
Old 02-25-2008 | 03:22 PM
FactoryJaguarTech's Avatar
Default RE: Coolant Leak with Picture
There is a gasket under there. The cap is only a few bucks and comes with gasket.
Your t-stat housing looks a little worse for ware too.
Old 02-26-2008 | 03:48 PM
Fixed for $24 includeing jag coolant.
Now on to the oil leak.
Thanks.
Old 02-26-2008 | 04:55 PM
ken@britishparts.com's Avatar
Check out our metal housings in the Motorcars field at the bottom of the forums list.
Old 02-26-2008 | 07:45 PM
Ken are they the aluminum housings? I have heard of them, but never seen one on a car yet. Do they work well? I may be interested for wifes car.
Old 05-28-2009 | 08:41 PM
nicknack's Avatar
Any more info on the aluminum T-stat housings??? Do they work well?
Old 05-30-2009 | 08:01 AM
sparkenzap's Avatar
Yes:
The aluminum Tstst housing looks as if the part was made from a mold of the original plastic. (might be!)
BTW How do the pros r/r this part. I made two wrenches out of cheap open end box wrenches - crowsfoot arrangement plus ground off edges and sides. Took about 10 hrs, or a little longer because I took it slow. Iknow the manual says to r/r the intake manifold but I did not have any gaskets and did not want to wait to get some.
Old 05-30-2009 | 03:01 PM
stran0020's Avatar
I have the same exact leak, not as bad though as i can see/ i will be upgrading to the aluminum housing and different t-stat from eurotoys ( http://eurotoysltd.com/catalog/produ...oducts_id=1173 )
does anyone have any experience with this different tstat from eurotoys? if not i will most likely go OEM
Rivguy
12-04-2020 08:55 AM
Booskisjag
05-05-2016 10:38 AM
OkieTim
09-08-2015 05:48 PM
Xkr x100
09-06-2015 09:50 AM
OkieTim
09-02-2015 01:48 PM
