Coolant level low warning
Guest
Posts: n/a
Hi all,
My 1999 XJ occasionally flashes up with "coolant level low" warning on the dashboard. The tank is full and there are no leaks. The warning dissapears after 10 seconds or so and then a few mins later comes back on.
It seems to do this when I am on the motorway/freeway travelling at speed 50+MPH
Any ideas or help would be much appreaceated.
Matt UK
Matt UK
Tank may look full,but squeeze the radiator hose slowly with the tank cap off. First the fluid will go up so don't squeeze too hard. When you release the hose it will pull the fluid down in the tank. Do this a couple times and your tank will need to be topped off,once topped off you should not have the light any longer.Goes without saying ,do this when the engine is cold. If you open that cap with a warm engine,you'll get burned and fluid will shoot out all over your engine.
SirJag (05-14-2011)
Wolfy
05-28-2024 08:06 AM
