coolant question
hi guys . I want to change the coolant now as I read in the forum the Prestone Dex-Cool 50/50 coolant meets my car specs my question is should I add 10 liter of this coolant or I must add 5 liter of coolant then add 5 liter of water ? so the total is 50% coolant and 50% water ?
im really confused about this thing what should I do?
thank you .
thank you .
If you purchase the 50/50 mixture then the water is already added, as I understand it. Based on that you would just fill it from the bottles and not add any additional water.
What I do is buy the un-diluted concentrate (not 50/50) and then add equal parts pure coolant and distilled water. That seems to come out a little cheaper but I think either way is fine.
running antifreeze in hot climates is that okay?
Look in your owner's manual for the acceptable ratio range. In hot climates you can almost certainly run something like 60 water/40 antifreeze. I am sure somebody here knows the limits. Antifreeze is not just to prevent freezing but it lubricates and nourishes certain parts of the cooling system. That's why you do not want to run straight water unless it's for very temporary flushing purposes.
In Malaysia, I use 1 part concentrated antifreeze with 2 parts of distilled water. This is probably still sufficient concentration of antifreeze to provide lubrication and anti corrosion. If you live in the area where the temperatures do not drop below freezing, it is better to use this concentration as the coolant mixture with less antifreeze has better heat transfer efficiency.
05-03-2023 08:44 AM
Bills
03-30-2022 08:02 AM
MattSteele
09-02-2014 11:11 AM
philhef
07-12-2014 01:49 PM
