Coolant reservoir leaking...
Replace. Last thing you want is an 85 mph reservoir burst and overheat.
On a side note, I purchased a coolant pressure tester this week for my fleet (family of 6 drivers) and it has already paid for itself with the first use. (didn't have to hunt and peck for the leak it showed up as soon as I added pressure) If you do not have one, spend a few bucks on it- well worth the $.
Tirefriar (05-08-2013)
The sensor is not a source of leaks. While some have patched it, I think you will find the plastic cooling system parts have become brittle with age and heating cycles. Considering the risk of severe damage due to overheating these engines it would be my choice to replace it.
X308XJR
05-20-2019 06:50 PM
