Coolant return tube.
Hi all,
Not sure I called it correctly in the heading. I've been replacing knock sensors trying to cure a "restricted performance " code on my x308. Upon reassemble and installing the engine covers when I went to snap the two pipes onto their holders on the drivers side, the one from the thermostat housing was very brittle and broke in several pieces. It runs from the side of the thermostat housing to the back at the holding tank. Can someone please help me find a part number so I can reorder this. I hope you can understand my description of the needed piece. Without it the engine sprays coolant all on the right side.
Thanks all for all your help.
David, have you not used Jaguars own parts site?
Jaguar XJ Series X308 parts | Jaguar Classic Parts UK
and your part
Expansion Tank and Recovery Bottle - Parts For XJ Series from (V)812317 to (V)F59525 (X308) | Jaguar Classic Parts UK
and your part
ericjansen (03-22-2017)
Go to eBay and search this number.
They are new about $ 35 bucks
It's a thermostat bleeder hose.
