Coolant temperature sensor wet?
Hi all,
2001 VDP not supercharged
I got a low coolant light today. Sure enough it's a little low. As I've had difficulty in the past with the sensor being loose/out of position, I pulled it out of there to look at it and it was a little wet. Should it be? It's been a while since I've had any problem with it and I just can't dredge up that kind of fine detail in my age addled brain.
Thanks ahead of time.
Andy
Andy
The following 2 users liked this post by RJ237:
Don B (05-02-2020),
motorcarman (05-02-2020)
The following 2 users liked this post by Addicted2boost:
Don B (05-02-2020),
That makes sense. I'll look at it but that's probably not to herd to change out. Thanks!!
Doh! You are absolutely right! Sorry about that. Yes, the level sensor. Do you agree it's likely a cracked tank that should be replaced?
I got around to replacing the tank today but over tightened the forward mounting bolt and boke it off. I was trying to remove the broken end out of it's plastic home and it appears to have a splined end in the plastic. I got a hold of it with vice grips an I can wiggle it but it won't pull out of there. A ny ideas?
janesjag
06-22-2015 01:32 AM
oldmaned
06-21-2014 09:19 AM
