Coolant Warning light Problem
Hi guys,
ive been having some recent cooling problems, I've had a new water pump and thermostat and the problem had seemed to go away, however the last couple of days I've had the 'Engine Coolant Low' flash up for no more than 30 seconds then it goes off. My coolant level is absolutely fine I've checked it.
What at do you guys think? Coolant sensor?
Any my feedback would be appreciated!
Kind Regards,
Lou
Kind Regards,
Lou
If it is coming on and going away it might be the internal float sticking. It is a little tough to get to but it is in the forward inboard corner of the tank. You might try manipulating it up and down a few times to clear any build up on the tube it rides on. If that doesn't resolve it you might have a bad pressure cap that is releasing fluid to the overflow tank early and then when shut down returns it to the tank. If it isn't holding pressure it will vent to the overflow.
kind regards,
Lou
