Cooling problem?
Guest
Posts: n/a
Hi. Over the past month or so I've noticed that my cooling fan comes on for about 30 seconds almost every time I turn off the motor. It also happens occassionally while idling. I don't recall this happening last season and the weather in Southeast PA as not been that warm.
I do get heat in the cabin and the temp guageshows no problem. I have not changed coolant in the 2 years I have owned the car and have not needed to add much.Is there something I should check?
'01 XJR
'01 XJR
Guest
Posts: n/a
As a point of insurance it may be an idea to change the water pump - this can wear quite quickly as they are plastic inside and have a tendency to break up - if the engine is does start to over heat because of a faulty pump it will do so very quickly and then you could be into big money. A new pump should cost about 100 $ +/-.
Hope it's ok. Cheers
G.
G.
