cooltant tank hose part number help?diagram will be helpful
Ebay seller has a used from 2000 JAGUAR XJR SEDAN 4-DR (4.0L V8 DOHC 32V SUPERCHARGER) EXPANSION TANK BLEED HOSE - Part Number: MNC4582BC Looks like it has quick-connector on both ends of the bleed hose
Please note that this XJR bleed hose is different from the XJ8 normal aspiratated Engine one - XJ8 bleeder hose is part# MNC4582AC and only has a quick connector at the expansion cooler tank and a short rubber hose at the other end:
Jim Lombardi
Jim Lombardi
coolant tank bleeder hose part numbers for XJ8 & XJR
Corrections to post number 3
Bleeder hose for XJ8 is MNC4583AC XJ8 bleeder hose is part# MNC4582AC has a quick connector on both ends of the bleed hose
JAGUAR OEM MNC4582BC Coolant Bleed HoXJ8 bleeder hose is part# MNC4582AC se 4.0 S/C to Vin F45010 MNC4582BC only has a quick connector at the expansion cooler tank and a short rubber hose at the other end (top of radiator)
