Crank no start after cam swap
So I have a 1998 jaguar xjr supercharged, i recently did a engine swap on it( i put an aj27 engine into it from a 2001 xjr) , then after doing the swap , i swaped the cams from the aj26 and put them into the aj27 engine. Hooked everything up ,cranked it a few times and it started for about 30 seconds with me feathering it. Now I can't get it to start at all it just cranks and cranks , like it did before I swaped the cams. Has anyone had this problem before or know how to fix it . Or what things to test to further diagnos it ? Please be detailed
You did set the valve 'lash' when you swapped the cams, RIGHT????
The lifters are NOT hydraulic and there are shims to set the proper clearance.
BORE WASH??
You only need to swap ONE CAM. The 'B'bank intake. All other cams can be left in place. There is no CMPS on the 'A"bank for the AJ26 engine. The 4 lobe reluctor will not matter.
The 'B'bank intake cam needs to have the SINGLE reluctor. The CMPS needs only that one for proper engine management. (AJ26)
bob
BORE WASH??
bob
Bore wash is common. Engine doesm't run long enough to get warm. Excess fuel washes the oil off of the cylinder walls. Really bad compression is the result. The engine will take a while to start.
Try simply holding the key in position for a while. Not kidding. Crank it a while and it might splutter back to life. I had to crank mine a good 40 seconds non stop before it came back to life... Or you can put a dab of oil in each cylinder turn the engine over a few times, fit the spark pkugs again and then try.
With a bad cam sensor, you can still start the engine if you keep the ignition in ON position for about 40 sec. before cranking (during this time the TCM will detect bad cam sensor and redirect itself to reading the crank sensor instead). Of course, the engine will start is the crank sensor is good.
flyhog
11-03-2016 09:14 PM
